Beocord 8002 shipping damage
Hello everyone. I was recently sent a Beocord 8002. Unfortunately, the packing job wasn't quite up-to-snuff, and several of the buttons on the front panel have somehow been pushed out of their normal slots, and are floating around within the case. Along with this, I found several plastic fragments among the bubble wrap which had been wrapped around the unit. How are these buttons normally held in place? Also, how do I open the unit in order to try and put things back the way they should be? Thanks in advance.
-Adam
I think this is probably identical to my BC9000: To open the case, you simply loosen the two screw at the back, and flip the housing open towards the front like a clamshell. Good luck!
Rudy
Sounds like you have got quite a bit of work ahead of you! I hope you payed very little for this...?
So you know sounds like the clips have snapped which hold the board to the front panel, and thus holding the keys in place. Martin once came up with a good idea of bonding some flat head bolts to the panel underside and then securing the board to the panel using these bolts.
Yeah, I only paid about $40. Still, I'd like to have this intact so I can experience the wonders of B&O cassette decks (especially since this is one of their best). Hopefully, Martin can fill us in on how this method is employed. Once I have a moment, I'll open it up and take some photos, to see how bad the damage is.
-Adam
If too much is broken, the easiest thing would probably be to replace the whole front panel.
With the Beocord open, don't open the top part up to vertical but instead lift it a bit and pull it forward a
couple of centimeters to allow access to the bottom edge of the front (over the edge of a table or similar).
A couple of claws can be released from below and the button panel can be lifted up.
Maybe these claws have broken.
Anyway, I suggest you check it out good. It it took a serious hit, there may be other damages inside, broken boards etc.
How do I get to this point, exactly? Is this after unscrewing the two access screws on the back, or is there more disassembly required? Anyway, here are some pictures of the front of the unit, as received. I can take more photos, if required.
Beocord 8002 damage 1
Beocord 8002 damage 2
Becord 8002 front panel damage
I can make them larger if necessary.
-Adam
Oh dear!
Badly packed is a bit of an understatement! What's the wood like? It looks very dirty too...
Anyway, once you have loosened the screws, just flip the whole thing open like a car bonnet!
How to remove the panel will seem obvious while you're in there.
My advice is to download the service manual 😕 which shows how to do it if you don't feel confident.
You will also probably be surprised to find, inside:
- loads of black goo, once belts,
- leaked, once viscous, oil from the opening lid system, loads of it too (at the back, above  the mech and, yes, all around the place!)
Good luck, we've been there!
The front right corner of the wood is a bit messed up (possibly the impact point), but otherwise seems intact. The area under the transport cover door looks OK, and the door itself still works fine. The guy who sent it to me claimed it was working, so hopefully there won't be too much to do to it once the shipping damage is fixed up. I'll try and post some more pics as soon as I have time to open it up, to better get a glimpse of the carnage.
-Adam
An update!
Thanks to a friend of mine, the front panel of my Beocord 8002 is once again as it should be, and the unit seems to be working perfectly! 😁 He used a combination of the old plastic clips and some metal brads to re-mount the contact board to the back of the button bezel, and all of the buttons I've tried thus far work fine (had to use pictures of other Beocord 800x units to determine which button went where). Plus, after replacing one of the belts and working on the pulley assembly, the transport is running nicely (haven't tried the record function yet). Gotta love the real-time counter. This has to be the coolest cassette deck I've ever owned (which makes sense, since the Beogram 8000 is the coolest TT I've ever owned). Thanks for all the help! 😐
-Adam
Score!  Congrats!
