Thanks, I will have a look at this carefully! I don't think I bent anything there but it is possible whilst the transport was upside down. I did place it on a flannel to try to protect it everything. Would it likely be bent too far inwards or outwards?
Downwards. So it hits on the front edge of the cassette.
Check if it will engage with no cassette inserted.
On a side note, the little brass fan type thing, that spins around as you eject a tape. What exactly does that do? Is it a type of governor to slow down the tape eject?
Yes, It's an airbrake.
