Beocord 7000 Repair Queries
Hello all, new to the forum! 🙂
My Dad has asked me to have a look at his Beocord 7000 (owned from new) which unfortunately isn't working properly any more.  Thanks Dad!  The drawer opens and closes fine and the tape player makes a noise but does not work.
I have dismantled to access the tape deck which I have lifted up to see the brass wheel and white wheel on the underside.  I removed the elastic band linking these the wheels.  When I press play the white wheel spins clockwise.  The same happens when I press fast forward or reverse.  The stop button does not stop it.  Only switching off the power will stop the wheel.  It also spins for a few seconds when switching the power back on and then stops.
Everything else moves ok manually but none of the buttons will get the tape spindles to operate or the large silver wheels with the thick belt to move.  None of the other functions works from the buttons (eg auto reverse etc).
I am wary of dismantling the deck further (eg removing the metal cover with the brass wheel) as this looks very fiddly to put back together and I don't have new belts for the large wheels.  It also seems that it may be something more complex than just a new belt to fix it.
Can anyone with experience throw any light on this for me please?  Many thanks in advance!
Thanks for the reply Weebyx!
I have changed the belts with parts supplied but this hasn't improved the situation unfortunately.  All buttons seem to elicit the same response - the white wheel (connected by a small band to the brass wheel) turns clockwise at speed when the band is not in place as described above.  Otherwise still nothing.
The display responds to the following:
Dolby button cycles through B, C and off.
The auto reverse button shows a flicker of an attempt to change sides from 1 to 2 but then gives up.
If you double press fast forward or rewind you get a strobing of the LEDs on the left of the display.
Does anyone know what I might be able to test to try and isolate the problem further?
With the wealth of experience on here does it sound like this unit has just reached the end of its (warm and lightly used) life?
TIA.
Are there any of the other Beocord decks that have the same plastic in the tape transport? I was going to change pelts on mine 7000 and lost the plastic part on to the takeup roller. Crack! And I have not been able to get that into position again 😠
