Hi Dillen
I'm looking for a spare motor for a Beocord 3300 with an integral regulator pcb - do you have one?
Cliff
Hi Dillen
Cliff
Hey Martin: I have the BeoCord 4500 and the tapes play back and forward, but no sound is heard to the speakers.
My Dolby circuit board image is attached. It has but one Capacitor compared to two for the BeoCord 3300. Does this mean just the one capacitor should be replaced ?
Thanks...[View:https://www.icloud.com/sharedalbum/#B1AGegcvgGSvXBr:800:0]
Maybe try this URL
Yes.
Thanks Martin.
I received the capacitor kits for the BeoCord 3300 and 4500. I replaced to current capacitors in each of them, and now... THEY WORK wonderfully well.
I'm testing them playing a tape with Beethoven #8 and #9 repeatedly for several hours to make sure they 'hold up'. So far no problems and the sound/misic playback is sublime.
Thank you for all your help.
Now I must try and figure out after replacing Capacitors etc that I received from Beoparts-shop on my BeoGram CD player has not resolved the issue of it spinning up the disc and then a few moments later spinning it back down to a stop, and placing a "?" in the display.
