Hello!
I bought a Beocord 2000 and Beomaster 2000 second hand about two decades ago. They came as a package, but it was the amp / tuner that I was mainly interested in. The cassette unit didn't work anyway. Well, I rediscovered the cassette unit about a week ago (had been at the back of a wardrobe since I got it).
I've replaced the belts without issue, but I have another issue. I believe the belts had snapped / perished when I bought the unit and the drive was jammed (complete with cassette still in the unit). I manually wound the heads back by turning the flywheel to extract the cassette, but there was a small metal pulley that was engaged with a rubber pulley around the right hand drive spool (forgive my lack of knowing the right nomenclature). Two decades with the metal pulley pushing against it has created a divot in the rubber pulley. When fast forwarding the driven pulley is losing traction when encountering this divot. When playing, the divot creates a rythmic mechnical noise that is very annoying.
So I would like to replace the right hand drive spool, or just the rubber part, if it is available separately.
Does anyone know where I can get this part from? If it's not available, is this a common failure? Would a spare parts Beocord 2000 be likely to have the same issue? Or be worth the risk?
Thanks in advance, any advice is appreciated! :)
