Hi there, my Beocenter 9500 and another Beocenter 9000 are not saving the settings anymore after turning it off or in stand by. Is there a battery which is responsible to save the settings ? If yes where is it placed and can it be replaced ?
Beocenter 9500 not saving SOUND settings
It's probably the battery, which for the BC9500 is here (red circle marks the spot!):
EDIT: And yes you can replace it but it is a little tricky to get to. I replaced with one of these: link
ah there it is. Tank you so much for your help !
I thought that sound settings have to be saved through beolink 1000....
