Hi
First post here, after reviewing many, many threads about the CD4 mechanism and board used in the Beocenter 9000. I have the usual problem of disk rejection, failing to play, etc, with the occasional play on really clean disks. Naturally C2103 is the assumed culprit.
I replaced C2103 with a Vishay 030 BC 47uf 16v capacitor, axial. I think the problem is improved but not much. Is it because the capacitance is wrong or the type (030 series)? I've ordered a Vishay "MAL203851339E3 33 µF, 50 V, 038 RSU Series, ± 20%" from Farnell in the UK, it's an 038 series capacitor. I've read that 47uF is OK if its a Vishay cap, but I'm not sure what the difference is in spec between 030 and 038 series caps - anyone care to enlighten me?
Also, I'd like to measure the laser voltage (50mV) but I can't see where the test points are on my board. It's because there are no markings for any of the resistors and I don't have a schematic or layout despite searching the Interwebz for ages. Yes, I found various pictures and other information about the CD4 as used in the 9000, but they seem to have different PCBs to mine. I also found a Beocenter 9000 service manual in Dutch and French but it hasn't got the CD PCB layout or schematic.
I've attached a picture of the board (click to see it all). Can anyone provide a schematic / board layout for it so I can work out where the test points are, please? Best I could find was the 9500 service book but it has the wrong PCB version.
Finally, I noticed the player seems to work better when it is on its side (in the "maintenance position" as the manual calls it). Not sure what this points to.. maybe the ribbon to the head is marginal? Looks OK..
JonB
