Hi all,
I have some trouble with a Beocenter 7700.
I can only switch it on/off with the help of the power cable.
The display shows “0” and “P” and additionally some recorder leds on.
It is impossible to control other functions, all the keys doesn’t react.
It looks that the Beocenter boot and then freeze on the mentioned display activities.
Normally it is possible to test the microprocessor with “Stand-By” + “Record” , the result should be “0” and “P” for an intact microprocessor. I cannot start the test because the keys don’t react but the display shows actually these both characters (sign that the microprocessor is OK?).
I founded somebody which had exactly the same problem in the Net, but till now I didn’t get any answer.
Any idea where I can look at? Is it possible to reset the microprocessor?
Greeting from a French in Germany
Jean-Jacques
