beocenter 7700 Help!
Hi,can anyone tell me where to find the voltage switch on the Beocenter 7700? Ijusy bought one from the States and i'm in Ireland. I assume it is set for 120v and the manual says to change the voltage via the switch in the base,but i can't find one! Help! Iwant to turn it on!!!
Thanks, Bill
Hello Bill.  Welcome to Beoworld!
The voltage selector is indeed on the bottom panel, If you open the 'Programming" cover and locate the Treble control, the voltage adjuster is located directly underneath.  The easiest way to adjust is from underneath.
Hope this helps.
Hi Ray,
   Thanks for the quick reply but maybe i'm a bit thick. Do you mean i have to unscrew the programming panel and lift it up to find the switch? I can't see any way to access it from beneath the machine.
Thanks, Bill
Do American units have a voltage selector?
I hope so! I would have thought the purpose of a voltage selector would be they wouldn't need a special model for the U.S.
