Beocenter 7007 remote
Yep, belts are in stock. Mounting instructions can be included, they will also tell you how to get in there.
I may also be able to help you if the motor has died but check fuses first.
The little part you've found is for stabilizing the cassette tray, the Beocenter will probably work fine without it. Actually finding one with the part still in place is not very common.
I confirm that the terminal remote works well from the 7000 to the 7700 (I have the 7007/7700 ones). For the part broken remeber that it "contains" a little ball that could be found inside the Beo under the tapedeck (if it is not gone out). If you find it you can fix the part removing the left plastic on the opposite face of the tapedeck and locking it using a little bolt (if you are a maniac like me 😳 ).
ciao ciao
PS
Ben, I already posted in the "Wanted" forum that I do have a BC7700 remote.
Please contact me If you are interested.
It is for free (or a friendly donation to beoworld.org 🙂)
regards
alex
