Actually I'm testing with headphones because I don't have speakers.
Right now the TT doesn't even spin because I suspect an electrical issue. Maybe I shorted something?
It's hard to describe the first scenario, but I'll try :
There 2 gears /sprockets under the TT. When the record gets to the end this gear / sprocket is supposed to toggle a switch. If the switch gets toggled the arm resets itself to orginal position.
if I lift up the TT slightly, I can push this with my fingers & it works as it should. However it doesn't do this by itself when playing records normally. It gets to the end of record then just stays there.
When I lift the TT a little and peek underneath I can see that it is almost at the part in the sprocket that toggles the switch.
At one point I had everything working except the part where the TT resets to original position. But I could manually do this by lifting up the TT slightly and nudging the sprocket underneath.
But the bigger problem now is that there is no sound.
When I push buttons I can hear clicks. No radio anymore. TT doesn't turn at all. If I push the "TURN" button it turns slowly for 1 sec then kaput
I'm wondering how I can troubleshoot the problem with no sound or electrical. I gave on the getting TT to work.
