Evening All,
I dusted down this Beocenter that I recapped a few years ago with the intention of sorting out a longstanding tape playback problem.
All mechanical functions appear to be in order (I fitted one of Martin's nice belt kits), but tape playback is at best in one channel only, or very faintly in both.
There is clearly a problem with or in the vicinity of the P53 connector on the Dolby board as gently poking it causes left channel dropout or resumption. The VU meter works correctly.
The l and r signal out from the tape section passes through 2 J-FETs which are turned on when +30V is applied through a couple of reverse biased signal diodes.
I have the correct +30V on playback (and the correct -15V in all other conditions). The two signal diodes are good (but I replaced them anyway). The J-FETs appear to be good.
I don't have a test tape so is there any way of injecting a signal from a generator to try to establish where it's dropping out?
Thanks,
Simon
