Hi Everyone,
Just wondering if anyone can help me, yesterday I got myself a Beocenter for a bargin! only £40 I have plugged it in and connected it to my Beovox s35-2's and I must say it sounds great. It is fully working apart from the odd sticky stitch what I believe is common and the issue with the record deck. When you switch the unit on its just spinning constantly the only way to stop it is to switch the whole unit off.
I have played a few records on it and its working great on 33 & 45 and the arm is working fine but the stop and pause are not working properly, if the deck is playing you press stop the arm lifts and go's back but the platter is still spinning constantly you just cant stop it, its almost as if the final bit where the deck clicks and stops is not there. Just wondering if a spray of contact cleaner into the switch would sort it out or if there is anything else I can do to try and sort it out myself without putting it in to the local repair shop.
Many Thanks,
Lewis
