BeoCenter 2300 back light
When the BeoCenter 2300 is turned on there is a back light that lights up the CD area.  Is it a way to have this light turned off (and still have the BeoCenter 2300 turned on)?
Welcome to Beoworld,
As far as i know, the only way to do it is to electrically disconnect the bulbs.
But knowing how difficult they are to source when they fry it would be criminal to do so!😁
So I suggest to matte the light window with some silver or aluminum tape.
(I can trade your working ones with two pre-fried ones if you really need them 🙂)
See this old thread for proper bulb replacement.
Hi
The BC2300 is designed like that. When opening the glass doors it light 100 % when closing it will reduce to about 50 light. It can not be turned off.
Brgds/Fritz.
