The RIAA pre-amp is sited on the board beneath the turntable toward the front of the unit,you'll need to remove the plastic moulding to access it.It's supply is shared with the tuner,so the fact that your radio section is functional,seems to exonerate that.Check the supply at the board,it comes in on P2-pin 1@42v.
On the board there is a regulator and decoupling cap that may need investigating(TR40,C41)The emitter of the regulator should be at 35v.
It may be a silly question,but are you confident that the pick-up cartridge is ok?
You should be able to "blip" the inputs to the RIAA pre-amp at P1 pin 5 and pin 3 to see if you get a corresponding buzz from each channel?
If you do,it definitely points to the pu or perhaps sheared connecting leads to the pu arm,they are rather thin and vulnerable.
I like these little units,they work well.
Nick
