Dear All,
I have inherit the above complete with a pair of Beovox S45 on stands. The foam surrounds have failed although I have the kits to re foam both. Beocenter 2002 has two problems; 1. The belt to the cassette deck has failed - should be easy to fix 2. The turntable has a nasty wobble - any ideas how to over come this. Or should I just be satisfied with my CDX, Beocenter 2100 & Beogram 6000 with MMC 20EN cartridge? The Beocenter is fitted with a MMC 20S cartridge.
Julian
