Beocenter 2 not working
Bought this set set and is not working . Only load CD works and open en close function . Power led burns and react on remote and hand touching with going of and on  but nu further  action by the beocenter . So nothing to see in the display .
So how to get some life back on it ? Can't give type or serial numbers because last owner removed them for what ever reason ?
You'll need the PIN code from the previous owner. Failing that you will need to produce your receipt to a dealer to get the Mastercode. But that needs the serial number......
Graham
I do have a pincode that came with it but it's not asking for one either when put on . Only the power led is burning and flashing when i touch some buttons .🙁
Mine was working fine, then I came home to find it unresponsive to everything - just blinking the power LED.  Any ideas?
Strange one. Best plug it out for a while and try it again later.
When the BC2 asks for a pincode, at least your dsiplay should work.
With what number starts the serialnumber on the socket?
