Beocenter 1 i.c.m. Apple TV HDMI > Composite/ S-Video Converter
Hallo,
Iemand ervaring met een apple tv hdmi>composite/S-video converter
95,- Euro is really expensive, here in Germany the converter just costs 45,- Euro:
http://www.amazon.de/Ligawo-®-Composite-S-Video-Konverter/dp/B002CBN81S/ref=sr_1_1?ie=UTF8&qid=1364379426&sr=8-1
Seems to be the same unit. According to the reviews it works but it's not the best quality you get out of the "normal" converters.
So do not expect miracles. I can't answer in your mother language, sorry. 😕
Bedankt voor je reactie. Vraag me af wat kwalitatief beter is, een AirPlay speaker van €200,- of de oplossing met de converter i.c.m. Apple-tv aansluiten op de beocenter 1?
Zeker de Apple tv op de tv aansluiten. Veel meer mogelijkheden via de tv en betere geluidskwaliteit dan een speaker van €200.
De beoplay a8 of a9 zijn dan nog weer een stap beter.
I have to answer in english, sorry, I can't write netherlands. 😁
I didn't have the chance to listen to the Beocenter 1 but if it is comparable to the Beovision Avant I guess you can save the 200,- Euro for the airplay speaker and just connect the Apple TV to your Beocenter 1 - which is a really beautiful TV by the way.
Most of the 200,- Euro Airplay speakers are ok/good for casual listening. If you are unsure: Just order and test one at home and judge for yourself what you want to keep.
Greetings from a german neighbour ;-)
