Beo Center 2 w Beo Vison 5
Hello,
I have the above connected in my master bedroom w option 0 for the BC2 and 2 for the BV5. I have 2 issues: 1. How can I use the timer on the BC2? 2. When I adjust the TV volume on the BC2 the TV shutsoff.
Thanks for your help ...
I have the same set up. The timer on the BC2 cannot be used when the BV5 is attached - you use the timer in the BV5 instead. I don't have a problem with the volume wheel on the BC2 though. Is the BC2 being used elsewhere for the radio at the same time?
My BV 5 does not have a timer ... not sure why that is. I have a US version. The BC 2 is connected wireless to a Beosound 5
