I'm an engineer (unfortunately not an electronic one) and long-term B&O afficionado. I've a Beosystem 5500, Beolab Penta and various other Beovoice speakers, and a Beovision Avant television. All still function reasonably well, but suffer from minor faults which I would like - if possible - to fix (or have fixed). Given some knowledgable guidance, I'm quite handy with a multimeter and soldering iron. I'm hoping that some of the more expert members of Beoworld may be able to point me in the right direction.
Beogram CD 5500 - It recently stopped recognising previously-recognised burned CD's. (It still recognises and plays bought CD's with no problems). I've tried freshly burned identical CD's, using both Roxio and Nero burning software, but still no recognition. None of the other CD players I've tried these discs (old and new) in (car, portable, other systems) have had any problem recognising them. I've cleaned the laser on the CD 5500, but that made no difference. What has gone wrong? And what needs to be done to re-enable My CD 5500 to recognise burned CD's?
Beocord 5500 - One of the red LED recording level lights no longer lights up. How can I fix this one?
Beolab Pentas - The yellow display on one of the speakers has failed. Nothing on the display lights up any more. (The display on the other speaker still works fine). These speakers can be a bit of a pig to transport, and I suspect any unnecessary jostling of this old equipment is probably best avoided. How can I set about fixing this?
Beovision Avant - Signal to this now comes from a digital set-top box. Output from the digital box is plugged into the SCART socket marked "AV" on the back panel of the Avant. The television can only be switched on by pressing the "DVD" button on the Beo 4 remote control - not the button marked "TV". It's a bit trivial I know, but is it possible to restore switching on of the television to the "TV" button instead of the "DVD" one?
Any assistance/guidance that you may be able to provide to help this old codger and his Beocodger equipment to keep swanning along will be much appreciated! Many thanks!
