Hi all, I found a local seller offering this model. I was wondering if someone can tell me how it compares to other sets like the MX4000 or MX7000? It seems that the two scart ports on the back are labeled VCR 1 (B&O AV1), Decoder (EIA:IS-15), do either one of these accept RGB? Thank you. Login to view image
Bang & Olufsen Beovision MX 5000 NTSC M Model: USA3250
AV1 has full RGB capability. The full service manual for this set is on the web site - you need to be a silver member and it is 46Mb in size.
Thanks Peter. The set I am considering has a low FW lever of 1.x, I have been told to try to go for 4.3 and higher so that I can access the service menu from the remote. This would be useful for me however I am more concerned about the picture quality which I have also been told is better in the later sets. Do you know if this is true?
