Just picked up another CD 5500 but it appears to have a really strange issue...
Power the drive on - press open and it the tray comes out nice and smooth. When you place a disk on the tray and press play it closes and attempts to read the TOC. This fails and the player enters standby mode, however the cd motor continues to ramp up speed for a good 15 seconds or so after the player has entered standby. If you press ‘open’ it just ignores it and continues to spin until eventually it stops, at that point it responds to open again.
The speed it achieves is WAY beyond what I would expect it to in normal operation.
I’m not having much luck with these CD players. My new years resolution is to listen to a cd in 2021 :-)
I was just wondering whether anyone has had similar issues or perhaps some suggestions on things to check? Any help will be REALLY appreciated.
