Avant US Firmware Update
I'm pretty certain that the capability of using a Zektor component switch box and the feature of the video slave mode require a chip upgrade. That's what my technician told me.
The feature of having the Avant in video slave mode is only relevant if you already have another B&O tv in your master link. You can't have two video masters in a master link network. One of the TVs would have to be assigned as a slave if the other TV is a master. If the Avant is the only B&O tv you have, the Avant can be in video master mode and play music from your audio master.
Thanks for your help, Jeff. I was able to take the Avant to the shop -Atlantic Systems - and the tech was able to update it right in my van. He replaced the chips (the ones I previously ordered from them) and updated the firmware. I was surprised how clean the tv was inside. Total cost was about $160 plus my gas for a 150 mile round trip. Still not bad at all.You will definitely need a qualified B&O service technician to come to your home to do the upgrade. I live in Indianapolis and a technician came from Cincinnati to do the job. I believe he charged about $500 to $600. He opened the Avant and replaced the chips and updated the PUC to the latest version to control the latest blu-ray players, Apple TV, etc. The update will give you the option in your setup menu to control a component switcher. The box that is controlled is made by Zektor. HOWEVER, you can find some very good switchers that can learn the Zektor IR command and that cost much less. You control the switch box by using a mini RCA splitter connected to the V.AUX control socket on the Avant and using an IR blaster. The switcher can switch the component input to correspond with TV, DVD, SAT, and V.AUX. However, I can't remember which order those are in. The $500 to $600 did not include fixing the faulty component input. The technician recommended replacing the entire chassis -- which sounded quite costly, so I passed on that repair. However, the technician DID vacuum out the Avant while it was open. I was amazed at how much dust and lent can gather in the Avant! That thing could have been a real fire hazard.
The component input on my US Avant 32 is having the exact same issue with a dark screen and the dark flashes on the screen too.
Did you have any success in finding a solution to eliminate this problem?
This is apparently a problem that other Avant 32 owners have had with their component inputs, so I'm hoping there's a fix that I can perform without having to pay big bucks to fix a 20+ year old TV set.
