As I don't have a BL7000, I don't know if it shows the volume when using that, but my Beomaster 7000 shows the volume in the display when I change it using my BL5000 on CD. Maybe there are different versions of the Beomaster? I don't know.
Hey Magnus,
in my case, the Beomaster 7000 doesn't show me information concerning the volume. May this be for the same reason that the Beolink 7000 is not showing me the volume information? Or are there different versions of the Beomaster?
And on a different note: most of the guys here recommend TV as Master and Beomaster as Slave. In my case the question is whether it wouldn't be better to connect the Pentas to the Beomaster? Peter once mentioned that it sounds better to him when Pentas are directly connected. What's better for listening to music? Two way stereo or four way stereo/dolby surround? What's dolby surround good for? Just for watching movies? I have a pretty tricky living room for positioning surround speakers since one needs to be very close to the main speaker whereas on the other side of the living room distance between main speaker and surround would be pretty big. Since I'm not watching a lot of TV anyways, I'm thinking about connecting Pentas directly to the Beomaster. It's a pity since my Dolby Surround module then is unnecessary, but I will need to make a compromise. Any thoughts in that?
Rgds,
Kai
Hi Kai,
I'm sorry, but I have no idea why your Beomaster behaves differently than mine...
Regard the different note: For music it is always best to use as many speakers as the music was created for. In other words: Two way stereo all the way! Four way stereo, or double stereo, is only suitable for parties or other situations when the music is only in the background. Dolby Surround is primary for movies, so if you're not a big movie watcher I would definitively connect the speakers directly to the Beomaster. Then the BL7000 should work perfectly! And the Avant is a very capable sound system on it's own, so you would still get better sound from your TV than most people. And as long as the systems are connected together you can still get the sound from the TV on the Pentas, for the odd concert movie etc.
Magnus
Hey Magnus,
thanks once again. I would have probably not needed software 1.3 then... However, this sounds like the way to go for me. And sound quality is supposed to be better that way. Do you still need Powerlink between Beomaster and Converter 1611? Or is AUX sufficient?
Rgds,
Kai
One more thing. If connecting the Pentas to the Beomaster and watching TV, the Pentas will probably not show volume level then, will they? Are there any other downsides of having the Pentas connected to the Beomaster? If not, why do most people recommend linking Pentas to the TV, having TV in Opt 2 and Master in Opt 0 then? Sorry for asking but I am confused...
Thanks very much for all of your help. Highly appreciated.
Rgds,
Kai
If you connect the Pentas to the Beomaster, they will not show the volume when watching TV, unless you transfer the sound to the Beomaster (press AV -> TV). I'm not entirely sure if the Powerlink cable to the converter is needed but I can't think of a reason why it should be. But it doesn't hurt.
The reason most people, like me, have the speakers connected to the TV is Dolby Surround. I use the TV as a center speaker and the Pentas as fronts and it really adds to the viewing experience. And I have bought a pair of Beolab 4000s to use as rear speakers as well.And by doing it this way you get a really nice integrated audio-video system, and everything just works very good together (unless you need the volume on the remote 😕). You don't need to think about the speakers at all, they turn on when needed, regardless of source. And I guess most people on here are so used to thinking this way that we just assume everyone wants it this way without asking...
But if you primary listens to music and are happy with the Avant sound alone for TV and not bothered with surround, it is perfectly fine to connect the speakers to the stereo!
Magnus
Thanks Magnus. That clears it up. Seems like you have pretty much the same setup as me. I'm not sure what I will do. Maybe I'll keep it as is and link speakers to the Beomaster, or I'll add some 4000s as surrounds. Those would fit my environment pretty well I suppose... Have you done the corssover tuning for the Pentas? I have Penta MK IIIs and am a little concerned that sooner or later they will need an overhaul. I've just had two Beolink 7000 overhauled and you can definitely tell by the brightness of the displays and the reaction speed of the two way function.
Regds,
Kai
