- the problem apparently is that sound processing is done by the Surround Module in the Avant. -
No. All IR commands sent by BL7000 will be received by your Avant and audio commands will be sent via ML and converter to your BM7000.
BM7000 (in A.OPT 0) sends audio IR commands back to your BL7000(s). It`s not the surround module.
- However, if I'm not already completely retarded I could swear that in that case both Beolink 7000s displayed volume correctly when only connected by the AUX cable to the converter 1611. However, controlling volume with the Beolink 7000 was then not possible.-
So, try it again. Disconnect the PL cable and reset the whole system by disconnecting all products from the mains and reconnect them after a few minutes. Maybe it will work...(?) I have no experience with BM7000 SW 1.3 . But as far as I know your system (converter) needs the Datalink information from the BM.
- If I connected the Pentas to the Beomaster rather than to the Avant, would then the correct volume be displayed on the Beolink 7000s? -
Yes. There will be source, track, volume data from audio sources displayed on the Pentas and BL7000.
- Would the Penta displays still work? -
Yes.
- Downside would be that surround sound is not possible with such a configuration -
There is always another option....
Next step I`d try is :
Connect the Pentas to your BM. Keep the ML/PL converter - ML connection to your Avant. Set your BM7000 to A.OPT 1. Set your Avant to V.OPT 1.
Set your BL7000 to AUDIO - 2 way, VIDEO - 1 way - should be already set to....(?). Surround speakers should be connected to rear PL outs of your Avant. You can add the Pentas to video sound using the AV button. - For example DVD - to start the Avant in DVD mode - AV - DVD to start the BM7000 and Pentas opening the AUX port. Maybe a workaround ...(?).
Stefan
