Is it possible to replace a Beosound 5 connected to a Beomaster 5 with another Beosound 5 without any problem?
Or are they a "unique pair" that can´t be replaced?
I believe the Beosound 5 is merely the display / user input unit for a beomaster, so unless I'm missing something, they should be interchangeable.
As we all are just guessing: If you have the opportunity, please try it and inform us if it works or not. Than we have facts. :)
Lee & Griebel: Thanks for your clarification.
Thanks Lee & Griebel!
I can now also confirm that it works fine.
No problems to change the Beosound 5 unit.
/Ola
