Nick, so the caps on the Laser PCB 02 were all Nichicon radials except one Philips axial. I replaced them all with good quality Nichicons. I may have misunderstood your previous post. I thought you said if they were Philips to change them. I didn't notice any difference after replacing them. One of the Philips axials measured low so I was hoping it would help to resolve one of the units. The Nichicons all measured OK, but I changed them anyway.
I think I also missed the part in your post about the caps on the Decoder PCB 05. I know I measured them all in circuit previously and they measured OK, but I'll have to double-check them next week to see what type they are. If Philips I will change them.
As far as the power supply, I agree that these regulated voltages are critical. I will try to locate and replace the -18v and -6v regulators with the proper type to eliminate that as an issue.
I don't have the test disc and laser simulator discussed in the service manual for making alignments, but I'll try to check what I can (motor, RF eye pattern, etc.)
Thanks again for all your help....I'm really looking forward to getting these fixed as one belongs to an important customer and the other is mine... I would love to add it to my system as the sound quality is amazing from what I've heard so far!
And, if you happen to find the training course that would be great!
Best,
Greg
