Hi everyone... I tried reading up on the common issues on these machines before posting, but I'm stuck on a couple issues. So, I have two of these on the bench right now. One is a customer's and one is mine someone gave me a few years ago.
I'll start with the issues on my machine and what I have done to it:
1. Original problem when plugged in was No power.
2. Located and replaced open 400mA fuse in power supply and two shorted diodes for -25v unregulated supply location 6458 and 6467 according to service manual I have.
3. Also found -6v regulator was at -2v and -18v regulator was at -14v. Didn't have them in stock so I fed the appropriate -6 and -18v DC supplies into the board with regulators' output pins disconnected.
4. At that point the machine would spin the disc for about 4-5 seconds then stop and give the infamous ? on the display.
5. Performed the griplet repair on both the servo and decoder boards, still has the same problem reading discs.
6. I also checked all caps in power supply, decoder board and servo board. No leaky or high ESR caps were found. I guess I could just change them all, but I've got a lot of time in it already at this point and I think it might be something else.
7. Anyone have any thoughts on this issue?
Now for the second one which is my customer's unit:
1. Original symptom was that it would play fine for about 5 tracks, then start skipping / struggling to track the disc. Same issue on any disc I tried.
2. Opened it up and found that someone had already done the griplet repair.
3. Cleaned and lubricated the laser arm and mechanism and cleaned the lens.
4. Disassembled the disc motor, cleaned and lubricated the shaft, brushes, etc.
5. Reassembled and started up at track 5. To my pleasure it played fine through tracks 5, 6, 7, etc. then it started failing again towards the end of the disc, tracks 10 and 11. I'm not sure if it was a coincidence or the improvement was related to the cleaning and lubrication I did.
6. Any ideas on this one?
Thanks for any help and sorry to post two issues in one thread, I just thought it might be easier to show what I've done and learned about these machines and hoping a CDX expert might chime in with some suggestions.
I hope you are well!
Greg
