Another CDX repair question
Hi everyone... I tried reading up on the common issues on these machines before posting, but I'm stuck on a couple issues.  So, I have two of these on the bench right now.  One is a customer's and one is mine someone gave me a few years ago.
I'll start with the issues on my machine and what I have done to it:
1. Original problem when plugged in was No power.
2. Located and replaced open 400mA fuse in power supply and two shorted diodes for -25v unregulated supply location 6458 and 6467 according to service manual I have.
3. Also found -6v regulator was at -2v and -18v regulator was at -14v.  Didn't have them in stock so I fed the appropriate -6 and -18v DC supplies into the board with regulators' output pins disconnected.
4. At that point the machine would spin the disc for about 4-5 seconds then stop and give the infamous ? on the display.
5. Performed the griplet repair on both the servo and decoder boards, still has the same problem reading discs.
6. I also checked all caps in power supply, decoder board and servo board. No leaky or high ESR caps were found.  I guess I could just change them all, but I've got a lot of time in it already at this point and I think it might be something else.
7. Anyone have any thoughts on this issue?
Now for the second one which is my customer's unit:
1. Original symptom was that it would play fine for about 5 tracks, then start skipping / struggling to track the disc.  Same issue on any disc I tried.
2. Opened it up and found that someone had already done the griplet repair.
3. Cleaned and lubricated the laser arm and mechanism and cleaned the lens.
4. Disassembled the disc motor, cleaned and lubricated the shaft, brushes, etc.
5. Reassembled and started up at track 5. To my pleasure it played fine through tracks 5, 6, 7, etc. then it started failing again towards the end of the disc, tracks 10 and 11.  I'm not sure if it was a coincidence or the improvement was related to the cleaning and lubrication I did.
6. Any ideas on this one?
Thanks for any help and sorry to post two issues in one thread, I just thought it might be easier to show what I've done and learned about these machines and hoping a CDX expert might chime in with some suggestions.
I hope you are well!
Greg
Hi, Hope everyone is doing well! I'm just wondering if anyone has any thoughts on these issues before I give up on them?
Thanks,
Greg
Don't give up on a CDX sir!!
In both your cases,the laser seems to be functioning as the disc wouldn't turn if it had failed.
Both cases seem to be due to the same thing-corrupted data from the disc,so the decoder is "dancing in the dark"?
The notorious griplets become oxidised within the solder,so I alway's drill through them,then wire through too,to make sure that the connection is good.
It's worth replacing the blue Philips(use the same type BC/Vishay)capacitors(33uf) on the little U shaped laser servo pcb mounted next to the laser assembly.Don't touch the presets there though!!!
If the capacitors on the decoder pcb are Nichicons,they will almost certainly still be ok,but if they are Philips,change them(22uf).
That lot should keep you busy?
Wonderful machines,well worth some tlc!
Keep us posted,
Nick
Hi Nick, thank you for the reply. I agree that these CDX machines do sound wonderful! I did de-solder and  feed thin wires through the griplet points and confirmed continuity from top to bottom of the boards so I don't think that's the issue.  I'll check the capacitors and report back.
Thanks,
Greg
Ok, so I replaced the caps on the u-shaped laser servo PC boards (even though they checked OK) and still have the same problem with both units. As mentioned in my original post, the first unit spins the disc but won't read it and then gets the "?" error on the display. The second unit plays fine for about 5 tracks, then starts skipping and having tracking issues. Any more ideas?
Thanks,
Greg
It could be an alignment issue with the door switch. I had a CDX that would not read and play when I loaded a CD and pressed play. I finally learned that I could gently press down on the glass door (on the left side) when it closed to help the switch engage and then the laser would read and recognize the disc. I don't know if that problem relates to you but it is something to check.
Also, when you are test playing the disc is the CDX still apart or do you have it reassembled?  I had another CDX that wasn't loading and playing when I tested it all opened up but when the cabinet was all put back together it played great.
They are cool little CD players but a little quirky.
-sonavor
The machine that is misstracking towards the centre of the disc,may need alignment of the disc motor lower bearing?This affect's the height of the turntable and so the focal length of the laser.It's quite a critical adjustment,but explained in the manual.
You don't mention the decoder capacitors I suggested for investigation?Are they Nichicons or Philips?
The power supply work that you carried out,might be significant?Are you confident now that all supply voltages are correct?
Nick
Sonavor, Thanks for the reply. I'm working with them apart, but I'm pretty sure the door switches are engaged otherwise it wouldn't attempt to play a disc.  I'll double-check them though.
Thanks,
Greg
Hi Nick, thanks for the reply....I'll check the disc motor bearing alignment in the manual and see if it helps.  It does seem like a disc motor issue as this is usually the cause of CD players that don't track well towards the end of the disc. Not sure why it would be out of adjustment, but we'll see.
As far as the capacitors on the U-shaped board... they were all Nichicon 33uf/16v expect the axial C2124 was a Philips 33uf/16v.  I replaced them all with good Nichicons and no difference on either unit. I even swapped the U-shaped boards from unit to unit with no difference on either machine.  I was surprised the one that plays until track 5 tracked with the different board, but it did.
In terms of the unit with the power supply work, I haven't bothered to order the -18v and -6v regulators yet because I was frustrated and didn't want to keep spending money and time if I wasn't able to get it to play discs. But, during tests, I'm feeding a stable -6v and -18v into the circuit board with the output pin of the regulators disconnected.  I'm monitoring the voltage as it tries to play and it's not dipping down, so I was thinking that part is OK.  But, maybe I just need to bite the bullet and order the correct regulators.  All the other power supply voltages are good.  To be honest, I was surprised one unit could have so many different failures (open fuse, two defective regulators and disc reading problems)....  I mean, this thing must have been working at one point before it lost power, right?
In the meantime, I'll try the disc motor adjustments and maybe play around with swapping power supplies and CD mechanisms from one unit to the other to see if I can narrow down the issues.
Thanks again,
Greg
Ok Gregg.
Well,it seems as though you have two machines that have been "got at" by persons unknown?
Something we all dread,as this tends to confuse the issue.
I think that you will need to return the machines to as original as much as possible?
I'm puzzled eg by the fact that you have Nichicon caps on the laser  pcb 02.These are usually Philips axials.There is much discussion about the particular characteristics of the Philips caps,and they do seem to work best here.Polarity is crucial with some of the caps too,as there are both positive and negative supplies involved
You still don't mention the cap's on the decoder pcb 05.If they are Nichicons,fine,but if Philips,they are suspect.
Confused?
The fact that both machines spin the disc,and one indeed plays a few tracks too,makes me think that there is not a major failing.
You need to remember that these cd players employ three (later machines 4!)servo systems,that all must work in concert for the disc to play.The most crucial time is at start up,so any psu problems will have a bearing then!
I have the original training course notes somewhere,I'll see if I can find and scan them for you,if it will help?
Nick
