Almando Multiplay Surround Switch . Condition is Manufacturer refurbished. The brilliant device is made in Germany and can be controlled via an iOS App or Android app. Cost £850 new and the listing is priced based on the unit being mint condition but open to sensible offers. Listed here & on other selling sites so the listing may end if sold. I reviewed this unit here on beoworld in the Beotalk podcast forum. Imported from Germany and can be used with all Bang & Olufsen speakers new & old. There is an RJ45 socket for connecting Loewe televisions with integrated DAL (Digital Audio Link) to the Digital Audio Link output of the TV. The RJ45 patch cable (CAT7) required for this can be bought anywhere for the required length. The unit is also compatible with sonos via the optical in. Full details from the manufacturer below https://almando.com/index.php/b-o/almando-multiplay-surround-powerlink-switch.html To connect Bang & Olufsen TVs, three RJ45 Powerlink sockets are available, one for the front speakers, one for the rear speakers and one for the center(R) / subwoofer(L). For newer TVs with RJ45 sockets you can use ordinary RJ45 patch cables (CAT7). For older TVs you need adapter cables (RJ45 Powerlink). Comes in original box with UK power cable, Optical cable, instructions. Comes with UK figure of 8 plug to 3 pin plug but anyone in Europe can replace it to a Schuko terminator. Technical Specs: Powerlink Signals Inputs 5.1 WISA Transmitter (Paid €200 extra for this upgrade) 8pin DIN input and all RJ45 outputs are 100% B&O compatible (even with BeoLab 5) - 3 x RJ45 (Powerlink) – 5.1 Surround for B&O TV - 1 x RJ45 (Digital Audiolink) – 5.1 for Loewe TV - 8pin DIN / B&O Powerlink (Beosound 9000 compatibility) - 1 x SPDIF - 6 x RJ45 (Powerlink) for B&O speakers (5.1) - 6 x RCA (Pre-Out) e.g. for Loewe 5.1 subwoofer, active speakers, amplifiers, active subwoofer - 12V Trigger Output (3.5mm Mono) for the wireless connection with up to 6 pieces WISA speakers / receivers (5.1 Surround) 100-240 V, 50/60 Hz 254 x 156 x 41 mm (B x T x H) 0,76 kg |
Almando Multiplay Surround Switch WISA £650 ono
Sold
