How can I add a local NAS or shared folder of music to BeoLiving Intelligence, I don't use streaming services as have a huge local music collection I want to use.
Thanks!
Thanks!
Hi mate,
Welcome to the forum.
There is a thread under home automation from Khimo, the company behind the BLI, not sure if you have seen it just yet
https://archivedforum2.beoworld.org/forums/t/36777.aspx
I watched a video on the BLI and i couldn't see. What i could see is that when you are making say a scene and you select the device and the source you want, it seems to me that it's picking up the source from the unit / beoapp.
I have found this link for you for the support documentation
With user guides etc
Enable or add a DLNA server on your NAS.How can I add a local NAS or shared folder of music to BeoLiving Intelligence, I don't use streaming services as have a huge local music collection I want to use.
Thanks!
and what’s the next step? I never could figure it out with the BLI app. To listen to NAS content, I still use the BeoLink 2 app and N.Music. To bad Khimo has not implemented this feature in BLI when using N.Music.Enable or add a DLNA server on your NAS.
the BeoLink 2 and BeoLiving app work the same with a DLNA server.If the server is up and running (on the same network) the app should see it!and what’s the next step? I never could figure it out with the BLI app. To listen to NAS content, I still use the BeoLink 2 app and N.Music. To bad Khimo has not implemented this feature in BLI when using N.Music.
I don’t see any content when using N.Music with BLI, unlike with the BeoLink2 App where I can browse through the content.If the server is up and running (on the same network) the app should see it!
According to the BLI GitHub it should happen automatically:
[quote]
On the BeoLiving app, you can access these media libraries by selecting any music source on a product (E.g: Music, Deezer, TuneIn, etc.), and pressing the “Content” button that can be found to the center-right of the screen.
Take into account that once the Storage device is connected, it will take some time to retrieve all the information on to the BLI. In the case of a full BeoMaster, this can take up to hours.
you are using N.Music with a BS5? Do you have a NL device? If so did you try Music as a source on this NL device?I don’t see any content when using N.Music with BLI, unlike with the BeoLink2 App where I can browse through the content.
Yes, I use N.Music with BM5/BS5No I don’t use an NL music device. This is the reason it doesn’t work I believe. However, the BeoLink2 App allows you to access the music stored on the BM5 without an NL device. For this the BLI is a downgrade compared to the BeoLink2 App.You are using N.Music with a BS5?Do you have a NL device? If so did you try Music as a source on this NL device?
