Accessing Beosystem 2500/Ouverture tape mechanism for belt replacement…
Thanks guys. I just had a second go and turned the big wheel to have the tapehead going away from the tape. Going beyond the natural limit gave the good result.
I am now playing a Tape, both directions and fast forward works !
Not so sure about Auto-Reverse for now, but different Problem for a different day.
The belt is from EBay, coming from Portugal. Makes a good impression.
Oh... I had a feeling. Don't ask why...
Oh my.
Christian,
Emails sent to your account bounces.
If possible please contact me from an account at another email server.
Dear all,
I am worker as an volunteer in a repair café and I hope i can get help for an problem with an beosystem 2500.
Following Problem:
I remove the old belt from the tape and set an new one, now i have some problems with the function of Play and winding / rewind.
After changing the belt it is now not possible to play music...
The head is after 5 sec. turning to the other direction and stop the play-function.
Is it importand that the wheels under the canpstan have an defined Position before install the new belt?
Perhaps can Help any one?
Best Regards
Beo_HP
Please see also the following link:
/forum/imported-unmapped/beosystem-2500-tape-kassetten-laufwerk-spinnt
Thanks! I just used your instructions to remove the tape deck of my BS2500, worked out well.
Excellent tutorial. Saved me a lot of time to read this before starting.
Here is how the belt should run between the wheels. The blue dot is the wheel on the motor.
I created a tool, kind of a hook, from a paper clip to get the belt onto the wheel on the motor. That step requires some patience.
