Follow the youtube tutorial to change the belt.
https://www.youtube.com/watch?v=JnAD5PbyBGA
Now, i come with a problem on the two BS i changed the belt. Even after replacing the belt the tape deck won't play, like still stuck.
I believe it's because when the belt broke or melt or whatever, the mechanism was in a certain position in the middle of something which need to be like reseted.
What i did is turn the main (big) wheel with the hand to what i call "the point beyond you think it will break".
Trust me when your BS will be up and running, you will remember it at the worst moment of all the fixing procedure!
But if you turn the main wheel and it dont spin freely you will have to do it until you hear a big "Clac" and it spin freely again.
Now it's done. Just do all the steps backward to re-assemble the BS.
Be careful, you're excited to see it working again, but now is very the time to be very careful.
Good luck to you all.
Hope it will help some people around…
