"If you looked at the video from Simply Speakers (and several others these days that repair speakers for consumers), they don't shim"
- I've seen the videos.
I've also seen all the failed DIY attempts arriving here. I had three last week, two M150 woofers and one S80.
And the prof. refoamers DO shim, they would have too many returns if they didn't.
But of course they want to make it look as simple as possible to the buyers and if a buyer fails the project and complain, they
will blame his skills or the woofers initial condition.
I've been there too with several foam suppliers and even more owners.![No - thumbs down]()
"the reason I did it this way was NOT to disturb the factory dust caps"
- Why is this important to you ? 😕
"there was a lot on moving the cone in and out to have it reach it's natural centering point."
- The cone/coil/spider will all have sagged to some extent, that's gravity and nature, in other words; unavoidable.
In some woofers (RL140 seem particularly prone because of its tight tolerances) this can in rare cases cause
the coil to start rubbing against the center piece EVEN with the surrounds still intact.
Surely, this is not where you want it to sit again ? ❓
In the above mentioned cases the spider will also have to be shim'ed back (or replaced - and shim'ed).
"sadly, you are wrong."
- Yes, that is sad.
And to hear it after doing a count of close to 4 digits of B&O woofers from all over the world over several
decades only makes it even more sad. 🙁
Well, having said that, I do feel a slight bit of comfort in the fact that I've not had one single negative feedback
on my work yet, let alone a return. 😳
If you are happy, then fine.
And no, you're not wrong - not at all. 😂
I have a huge respect for owners trying to fix stuff themselves but as one of this sites technical advisors, I will again have
to advice against doing refoam jobs without shim'ing.
It's so easy, cheap and fast and an almost 100% guarantee of good result so I see no reason whatsoever for NOT shim'ing.
I've seen too many woofers, that could've been saved, go to landfill.
These woofers are custom produced to B&O. They are long out of production and replacements with reasonably
similar T/S parameters can't be found anywhere.
I've also said this before; Some owners have more skills than others. Others again just have more luck.
If you succeded, then fine. You will know if you succeeded after a couple of months.
Just don't count on all DIYers to reach the same result.
I can tell you, not all people have finger skills for tasks like this ! 😂
