A beomaster 6000
Tone control board next...dial cord will have to be re-fitted when I'm finished, always have fun with those.
Had to remove this board to get at the two tantals sitting right in front of the tunning motor, will give that a coat of looking at too, and the feedback pot while the board is out.
Theres a lot to be said for these modular boards with the plug connectors, makes things much easier to access....
Micro computer next in the barrel...….
I know there are two fat boys hiding inside the screened enclosure...…..wont be doing anything else in here!
Sort these two out and get out of there...….
Re assembly under way....not had any issues with this unit, which makes a change....
Hi Craig
Greatj job so far, nearly at the end. I might be telling granny how to suck eggs, but when you put the black cover on over the LEDs, be Careful of the balance bulbs, I broke two on my rebuild.
I love this unit, it’s just as good as my Beomaster 4400
Keith
K. Parker
Hi Craig
Keith
K. Parker
Almost. The 4400 has a tone defeat feature (LINEAR) that makes it slightly more transparent and makes it my favourite Beomaster, purely on sound quality grounds.
They measured it at HFN&RR and found it thoroughly modern in its performances. 😎
That said, I will never part with my 6000, and keep it for one of my children.
