Hi
My 7007 plays tapes well, and with some tapes that have very loose reels inside them, rewinds well.
For tapes that have even a bit of resistance, the rewind drops out, I'm guessing the rewind must sense motor current to sense end of a tape rewind. Fast forward doesn't work at all , you hear the fast forward engage then drop out immediately.
Does anyone know whether it's likely a mechanical or electrical problem, so I can start looking?
Thank you/ Danke/merci
