4K Amazon Fire Tv
Hoping someone can help
Trying to use beo6 to control fire TV box
I have a flirc plugged into the fire TV
Trying to build a config on beo6 goes through a beosystem3 with an ir bud
Got part of it to work by modifying another device code but the more I messed the worse it got
Anyone help with how they have got theirs working please
Richard
My Amazon Fire was installed in my Avant 55 by the technician who set up my TV, and everything has worked fine via the beoremote for a full year, so B&O should be able to advise you.
However, I use the BT TV box for all my TV recording, playback and streaming, which can also be controlled from the beoremote.  You need to program the remote to recognise BT TV, which will then convert the remote's signal to the equivalent BT TV commands.  I produced this chart which details most of them:
Beoremote BT TV Amazon Fire
PLAY
Select
Play
P+ Up ChUp
P- Down ChDown
SkipRight Right Fast Forward
SkipLeft Left Rewind
PAUSE Pause Pause
PAUSE+PAUSE Stop Stop
BACK Back Back
EXIT Exit Exit
GUIDE   Start
INFO   Information
RED Red Start
GREEN Green Last
YELLOW Yellow ChUp
BLUE Blue ChDown
DIGITS 0 - 9 0 - 9 0 - 9
MENU + 1 YouView Explorer
MENU + 2 Guide
MENU + 3 Search
MENU + 4 Text Record
MENU + 5 Help
MENU + 6 AudioShift
MENU + 7 Delete / Subtitles
MENU + 8 Information
SHIFT + 9 Power Power
SHIFT + RED Record Red
SHIFT + GREEN   Green
SHIFT + YELLOW   Yellow
SHIFT + BLUE YouView Blue
SELECT Select Select
SELECT long Guide
UP Up Up
DOWN Down Down
LEFT Left Left
RIGHT Right Right
After a week or two you remember all the important ones.
By the way, you can also access Netflix (and much more) from the BT TV box, and Netflix content is vastly superior to Amazon video with no extra charges.
Hope this helps.
Brian
