4500 display mounth which 2 sided tape to mounth
Displays 4500 system will go loose.. off all the displays
Which 2 sided tape to use mouth ?
The absolute best product that I've found and used with much success is servo tape.  It's literally used for mounting servos in remote control vehicles.  Any online or retail hobby shop carries it.  It's much thinner than most double sided tape and is about 10 times as sticky and basically a permanent solution.
I used it on a couple of beocenter 9500s that I restored and it works perfectly.
Trust me on this one!
Greg
Hi Dolle Dries,
I have used transparant 3M VHB tape successfully for this. VHB stands for Very High Bonding and that's no lie. It is available in various thicknesses and widths. Not cheap though 🙁. If you need to do one machine, I could send you a bit I have left.
Regards, Johan
