Turns out it’s also really good at sending Beo4 commands. So my “French buddy” and I have put together a custom integration that makes the most common Beo4 commands available as buttons in Home Assistant. When you press a button, the command is sent over the network to the IR gadget above, which then sends out the IR command. In terms of range, I can confirm it works perfectly at 5m range, but since I have already stuck if under a shelf with 3M tape, I can’t test how much further it goes :)
It’s one-way control of course, but it opens up some interesting possibilities. For example, if you have an Audio Master connected to the line-in of a Core, you can have it turn on when line-in is selected.
You can find the integration here:
Hope someone finds it useful :)
Login to view image
