Hi GUys, anyone had any problem with the youtube channel on the avant? i had to reset to default the tv again and again to get it work, otherwise it will just be blank screen. Help pls...
youtube on avant
Nope, works perfect on mine. I have Youtube in many devices, but it´s easiest to use the Avant's version.
Dear all!
Since a few days the youtube App on my Avant75 NG does not start - it gets stuck on the login process - which should happen automatically; the app crashes and the TV says "youtube was shut down"; clicking on "report" does not lead to anything; I am just able to choose "ok"
I tried to uninstall the app but as is seems to be some kind of core software I am only able to uninstall the updates - the old version (with read screen at startup) does not start up/leads to another crash.
Login data available - updates are possible...
I also agreed to use TVs microphone (do not know if there is any) through update process as I thought this could be the reason...
Any ideas?
Best regrads
Elmar
Same here on a BV14 and Eclipse
I had the same issue on the Horizon. I expect that it is a bug in the last update of the Youtube app. I deleted all the updates and I do not receive any messages on the screen anymore after I started the Horizon up. When I want to use Youtube I use the app of the Apple TV.
thanks for your response - me too, using youtube now on apple tv...lets hope maybe there will be an update soon
best regards Elmar
