Thanks for the warning, kallasr! Can you tell me how I can recognize the right ML cable? If it's recognizable!
- Dennis
- Dennis
LINK might be helpful.
Ralf
You can use the normal masterlink cable but you have to make a short circuit between pin 4 (ML sense)and 12 on masterlink socket in MP AV9000 stereo
that have bin done in struer from serial number 10822537.
Can anyone confirm, that this will work? Cause then I'm going to make that operation (If the Serial Number is lower than 10822537)! when I'm opening the MPAV 9000 sometime to adjust the doors. 🙂
- Dennis
In
Allmighty BL9 😐
A pair of S120's.
Actual condition is worse than the photo's suggest so some work required here methinks...
Holy crap Chris, that's a challenge!
Nö,
geht auch mit den neueren ML Kabel:
Man muss "nur" im MPAV die ML Buchse PIN 4 mit PIN 6 brücken.Ulf wünscht frohes Fest
I
have fun with sanding sanding and sanding! New lacker and foamrings and have a look at the filter and they will be as good as new!
[quote user="Dennis (Loudspeaker)"]
I
