BeoFab wrote:
Karla wrote:
My latest purchase for B&O? An iPad2! We are intergrating it with the multilink via the BS9000 and it is amazing. We had previously completed the iPad2 to the Avant via the AppleTV2 so all is going very well.
Hi Karla,
Could you please explain how did you integrated the iPad2 with the multilink via the BS9000.
Thank you
The idea for this configuration actually came from BeoWorld member rxcohen from a thread that I started called Pc2 and iPad2, and it is a really elegant solution.
1) You are going to connect the BS9000 auxiliary input (DIN Socket) to an Apple Airport Express (3.5mm socket). This will require that you have a cable/adaptor configuration to connect with a DIN plug on one end and a 3.5mm male end on the other. The BS9000 DIN is 7 pin, but I have been told that we need only to use a 5 pin socket.
2) Plug in and configure your Airport Express and then synch the iPad2 to the Airport Express.
3) Connect the BS9000 to the Airport Express using the 3.5mm socket on the Airport Express.
4) Turn on the BS9000 to A. Auxiliary.
5) Turn on the iPad2 and connect to the Airport Express
6) Sit back and enjoy your play list! π
You should be able to operate the playlist anywhere within range of the Airport Express.
It is also possible to connect the 3.5mm jack from the DIN cable set up, directly to the iPad2 headphone output, but that is not nearly as cool.
