I'm going to replace the ribbon cable on the front panel of the Beomaster and change all belts in Beocord and Beogram.Nice boxes, I didn't like mine to begin with, but getting used to them, as you mentioned too new😂. Playing very good though, and use them everyday.
linkbelts and cleaning, clean all cable plugs and jacks properly. , belt and cleaning
Thanks, Søren and also thanks for the links. I'm going to disassemble Beocord right down to the bottom plate as you did, because the tray doesn't move without help. The motor runs, so it is not the problem.
When I press play, rewind or ff, the tape are spinning for a second and then shutting down. The solution would be more cleaning, new grease and new belts also here.
Previously I use a CD50 playing through BM 6000 2702 and I really enjoy the sound. It runs just as it was supposed to work, I think. The “new” CD50, however, does not work completely perfect in the tray, the same issue as Jacques had with his cd player. I did not remove and cleaned all the gear and therefore have homework to do. Martin might have the right belt although he doesn't advertise it on Bonanza?
I knew I had an MCL 82 somewhere and found it in a box together with the speaker connectors with 3 pins. It must of course be tested with the stack when it works! Remains to find the MCL-cable which is also to be found anywhere...
