I have had a demonstration of the Beosound Essence recently and I found it a pretty exciting product totally in phase with our time and what I was looking for. I have a question tough for the ones who own the product: which features are missing? What would you improve on the product?
Also, I have tried to find answers on the net but without success:
- Do you know what is the internal DAC used? Is it a very good one?
- What is the difference between MKI and MKII? Is there an upgrade option available from B&O?
- Can you confirm that it can play High Quality audio files (24 bit/192 Khz FLAC) straight from a hard drive as this format is still not supported by iTunes (...)? Should the hard drive be connected to the Essence?
- Do you experience a lots of audio drop in a multi room environment like I do with AirPlay on Airport Express?
Thanks,
Emmanuel
