I do have one other question. When I reinstalled the new IR eye a month back, they are spliced as I was not able to re-run wire directly through the wall to the MCL2AV in the garage from the IR eye in the bedroom. I used electrical tape to secure the splices in all the wires in the wall behind the IR eye. Is this a problem or fire hazard? Assuming from all our back and forth, there should be 5V going through the green and brown wires, so I wanted to make sure that the way I secured the splices with electrical tape is ok. Otherwise, I will have to go back in the wall and use a heat gun and soldering connections if need be.
