XTRA Speaker and MCL Issue
I noticed that Quality Dream Audio is out of stock on the one I have, but they have this one that I've attached. Would this work with my system? The only difference I see is the extra port for TV on it whereas the one I have only has the 3 ports, one being marked TV, which is the one that I use to relay from the bluetooth adapter to run my TV in the room above. Please let me know. I appreciate all your help with this, very frustrating.
When you are going to replace it a piece of advise is to also disconnect the power for the Beosystem 4500 to avoid any risk of damage anything in the process
Thank you Madskp - Is there anything else I should consider? Do you feel that the MCL2AV is the issue and that replacing it should resolve? I'll just disconnect the wiring from my existing MCL2AV and connect to the new one once I purchase and receive it. Then just keep my fingers crossed.
I would not suspect anything else at this point.
Oh one other question. I noticed when going in to order the MCL2AV, it has an option for Type Number: 2020, 2027, 2031 or 2026. I'm not sure which one to get, any idea on that? It looks like the one I pictured above with the extra antenna port you mentioned. Also, I will make sure the entire system is powered down when I re-attach after I receive it. Thank you again for your help.
2020 is the one with the Antenna port.
The other ones are without. The differences lies in which setup type the where bought for and if the had the IR eye or not. For your setup it should not matter
Great, thank you!
I personally wanted to thank all of you that helped walk me through this situation. I purchased and installed a new MCL2AV 2020 version from 1987 from Quality Dream Audio and I am back up and running, so that was definitely the issue. I made sure the system was unplugged, I attached all the appropriate wiring to the new one, well refurbished, powered everything back on and I am again able to use the XTRA speakers, the remote with the eye and all is well.
Again, thank you all!
Great to hear that you got it all working again :-)
Even though it's old the MCL2AV is a brilliant and versatile box in my opinion
