xbox 360 plays in black&white
hi all
i have just been given a bang&olufsen beovision lx5500, i have no manual with it but when i press AV nothing happens but it finds xbox on V.TAPE but it plays in black&white or very bright orange to purple. does this model tv support pal 60hz or just 50. i thought it would not show any colour at all if it didnt support 60hz. i know its not xbox as it works fine on a friends tv but only in the back scart not the front 3 plug (red,white and yellow) as that goes from colour to black&white every second would love some help as i have been on google far to long now lol
Hi Boon, and welcome to the all new Beoworld!
The AV button has nothing to do with it, that is just used for swapping sound between an audio system and a video system.
I'm sure someone will be along soon who has experience with an LX5500 and an Xbox.
Andy T.
Is the game region free, NTSC or PAL ? When you play NTSC games on a PAL tv you will see only black and white.
the game will only run on 60hz so i guess tv only supports 50hz. just thought it strange xbox starts up with day glo orange on the menu screen. so has some form of colour.
many years ago i had an ntsc dreamcast and had to get a converter to play it on the tv i had at the time as it was a pal tv. without it the dreamcast would only have black and white and never any other colour let alone the day glo
I'm pretty sure the LX 5500 can switch between Pal, Secam and Ntsc
Have you tried this?
Andy T.
i have tried to mess around with settings on tv but cannot work it out at all. i havent got an owners manual and as far as i can see you have to pay to get one. i dont realy want to pay for one if in the end it wont support anything but pal.
im normaly quite clued up on how to work a remote but this one beats me.
Hi:
Are you connecting the xbox to the TV via a scart to composite convertor - ie. do you plug a scart adaptor into the scart socket of the television and then plug red, yellow and white connectors into this, which then runs to the xbox?
If so, is this the one that was supplied with the xbox?
I have had simillar problems, cannot remember why, but I eventually sorted them out. I will try to help you rectify the problems you are having.
Graham
hi Graham
i have tried plugging it into av1 & av2 on the back of tv as it doesnt have the other red, yellow and white plugs. i also have 2 leads for xbox both ones supplied with xbox. one is the standard scart and the other is the newer scart with hd plugs aswell as normal scart plugs. both have the same prob :(
Hi:
Right OK, so your Xbox has a moulded scart connector that connects to the TV as opposed to phono plugs which plug into the scart convertor?
Could you provide a pic of what you have
One other thing, do you have anything else connected to the TV through the other scart namely Freeview/DVD/Cable?
Graham
the xbox lead has the normal games console scart end, the 3 plugs that go into the small scart adapter or scart converter (didnt know it was called that)
i have freeview in and works fine. xbox is still the same if freeview is there or not. it has to be a setting on tv i cant find or tv just wont suport 60hz games. my guess it doesnt support it. i have an old xbox that the drive went on but starts up fine and the same thing, swithes from b&w to day glo colour. makes games abit more intresting tho lol
