Would You try this?
Would anyone consider or have they tried an acyrlic scratch remover like this?
I use a metal polish to remove scratches from the plastic "glass" on watches.  Works very well indeed.
hi there
i have used silver polish on the acrylic penta bases to great effect - silver polish tends to have finer grain size than most other metal polishes - another alternative might be jewellers rouge although don't know how to acquire it
salut a la france
tony s
