Maybe it's technical not possible or to complicated to add WISA, as a working BL5 also needs powerlink data. I don't think a BV11/Avant transmits PL data..
WISA for Beolab 5?
So...now we have BL20 which has WISA. So it is technically possible.
B&O: When are you releasing a gadget which makes BL5's wireless without connectivity issues??
Not going to happen. BL5s are EoL. Shines ALT lens discs are the only further upgrade they will receive.
B&O: When are you releasing a gadget which makes BL5's wireless without connectivity issues??Not going to happen.
It's called "Chromecast", and it works flawlessly !
--> /forum/imported-unmapped/beolink-network-link-beolab-5-in-the-modern-era
David, I thought you were already using a Chromecast audio with your BL5s ?
Not yet. Considere it, but i'm investigating a wireless option first
I would like the BL5's to work wirelessly like BL20s. The CCA would then be connected to the transmitter...
