WISA for Beolab 5?
Maybe it's technical not possible or to complicated to add WISA, as a working BL5 also needs powerlink data. I don't think a BV11/Avant transmits PL data..
So...now we have BL20 which has WISA. So it is technically possible.
B&O: When are you releasing a gadget which makes BL5's wireless without connectivity issues??
Not going to happen. BL5s are EoL. Shines ALT lens discs are the only further upgrade they will receive.
It's called "Chromecast", and it works flawlessly !
--> /forum/imported-unmapped/beolink-network-link-beolab-5-in-the-modern-era
David, I thought you were already using a Chromecast audio with your BL5s ?
Not yet. Considere it, but i'm investigating a wireless option first
I would like the BL5's to work wirelessly like BL20s. The CCA would then be connected to the transmitter...
